I have a 2014 Raptor SD that I purchased new. I have had the same problems that most owners have had with the transmission mount bolts breaking. 1st time I took it back to the dealer to fix. The second time, I decided to investigate and found that Hustler had a heaver crossmember plate. So I ordered one, and upon installing it I saw that the mounting tab was broken off. See Pics. This was in 2019 when it happened and I just installed the plate with the broken tab in place. So, this weekend I installed the new heaver wheel brackets, and decided that I would ask you all if this can be fix without a total replacement of the transmission. I just mow my yard about 2/3 of an acre, mostly flat. I've not had any issues with it as far as I can tell.
