Hello,
I have a craftsman riding mower 12.5hp model 917256451. I cleaned the carb and after putting it back on every time I start the engine it automatically starts running at full speed. I put it on choke and it starts and runs fine but then when I move the lever to run the engines goes full throttle.
I’ve checked the carb installation against the manual and everything seems fine. I also adjusted the throttle cable per manual instructions.
One thing I noticed is that the throttle butterfly on the carb is loose and there is no spring to it? Might this be causing the issue?
I don’t recall there being a spring.
any ideas on what else to check before I start messing around with the governor?
Thanks in advance!!
Thanks in advance!!
