2468jamesmay
- Aug 22, 2014
- 3
- 5
I have got a briggs synchro balance 10hp engine which I have was having a few problems with.
I was having an issue with the engine running properly because it has always had a slight misfire. I have tried everything with the carb and even took the restriction plate out of the box type exhaust but I have just found after taking the sump of that the cam gear was out by one tooth on the crank gear.
But the main thing is it has a had a slight knock on start up after being left for a week or so, which Im not sure whether its normal.
I checked over the engine and found the eccentric cam has slight play in it and is it supposed the be like that or is it supposed to have no play?
Another issue is just before I had it apart it was blowing out a little bit of smoke that looked like it was blue but only really noticeable in a small space in the dark with a torch. The cylinder appears to be ok and it had good compression so any ideas on that?
