rh hutchins
- Mar 4, 2023
- 2
- 8
I have a Snapper self-propelled walk behind 21" mower whose model number escapes me at the moment. It has a Briggs & Stratton model 128607 Type 0113E1 engine. After sitting over the winter I got it out to cut grass. After cranking, oil was gushing out the engine where I would suppose the oil chamber gasket would mount to the bottom of the engine. I plan to break it down and replace all the gaskets and anything else I find that needs it.
The parts diagram I found shows a part number 358 called gasket set. I have no idea what this includes as it is not specific. I thought that since I have to break the engine down to install the oil chamber gasket that I would replace all other gaskets including the head gasket. The problem is that I don't have an adequate parts list AND I don't know what other gaskets I might need, such as the muffler/exhaust manifold and carburetor and whatever else that has a gasket. Isn't there a gasket on the shaft that drives the blade?
I would be grateful is someone can point me to a decent parts diagram for this engine and suggest reputable parts suppliers (and ones to be avoided).
