Greetings Lawn World,
I have an old Craftsman lawn mower with Briggs and Stratton 5.5 engine (Model # 128802-1519-23, yes, very old). I was having problems starting so upon examination, found that the primer bulb was cracked. I replaced that and while I was at it, changed the oil and spark plug. It started and ran great for one time only. The next time I could not start it. I have fuel and air so I fell upon the spark as an issue. I tested the ignition coil as per directions on YouTube (With the kill switch connected and unconnected) and found no spark. I bought a new induction coil but still no spark. I should say there is a very weak to non-existent spark, if I hold the plug in my hand I get a very weak jolt sometimes. I set the air gap on the coil with a business card that measured .010" with a caliper and also bumped it down to .006" with a feeler gauge. No luck.
I am grasping at straws to find a solution as there seem to be no other electrical components evident.
Could I really have Two bad induction coils?
Do I need to insulate the coil on the bottom where it mounts to the engine?
