I've got a Briggs 5HP outboard that I can't get the idle mix adjustment screw to the right position. Looking for some tips to help get it set right. I pulled the whole thing apart and cleaned it well. Put the idle mix screw back in and turned it the same six turns it took to bottom it out when I took it apart.
Now it will only run on full choke and even then I had to turn up the idle screw. If I turn it off choke one notch, it dies.
New fuel lines, new carb bowl and jet gaskets. Fuel pump is new. Carb is clean. Model: 12y602 0110 E5 030530 FA
