smallengineguy
- Mar 15, 2020
- 4
- 23
Intek Twin in a JD 140D Model 445577. Found that someone disconnected the coil ground wires so the mower would just shut off after the fuel solenoid cut off the fuel. I reconnected the ground wires to the coils and no spark. I disconnected the engine from the tractor harness, still no spark. SO what I have now is just the black wire from each coil, tied together and running back to the factory plug. Still no spark...Here's the funny part- If I unplug EITHER ground wire from any coil, I get spark. I only have no spark if BOTH ground wires are hooked to the coil terminals. The black wires have been checked for chafing, and are in fact held away from any metal surface all the way to the plug. Anyone ever seen this?
