Hi guys
Unfortunately I have managed to seize my relatively new lawnmower which is running a 675 Briggs and Stratton motor :frown:. I managed to free it up again, get it going and re added the oil and have been keeping an eagle eye on oil consumption. My questions are these since the mower is running without making any new knocking noises, not appearing to use any oil, seems to idle ok - could I have dodged a bullet in the short term? It does appear to be a bit down on power so I am thinking that long term I will have to repair/replace engine, what are the most likely parts that are going to need repairing/replacing ie conrods pistons etc. Also is it normal for these engines to burn quite a bit of oil if they are being used heavily - this engine has burnt through most of its oil in about 11 hours running from new and I topped up the oil myself. I know they burn a little bit but I was amazed that most of the engine oil was gone when the mower seized.
thanks for your help
Rick
Rick
