Hi All,
Just wondering if anybody could help resolve my mower issue. I have a 2.5 year old B & S 550e series140cc 2.2KW mower. Prod code: 8k12-019892
1. I transported it 1 mile in the car with the front slightly elevated (~40 degrees)
2. Cut long length grass for 2 minutes and could hear it struggling to cut grass.
3. It starting running at idle speed rather than full speed.
4. It was just about cutting the grass but I had to back off before it cut out.
5. Once it cut off, I could not restart it.
6. The pull cord now feels really stiff to pull, fine to pull when the spark plug is removed.
7. Spark plug is sparking fine, I've checked this but replaced with a brand new one.
8. The air filter is dry and looks brand new. I removed it for a few minutes and it still did not start.
9. I am using Aspen 4, 4 stroke fuel that keeps stable for 5 years. ( It does not smoke or smell!).
10. Mower now has fresh oil in, although previous oil did not look bad. Mower only used around 8 times since new.
11. Brake is removed while pulling cord, although I have not physically seen this disengaged.
Any help would be most appreciated, thanks!
