Phillip Campbell
- Apr 19, 2022
- 1
- 2
My wife bought this Toro mower used. As stated above, it starts first pull, runs, and mows perfectly for about 15 minutes then just dies. It sounds like the motor slows down right before it dies. The next day same story. Starts runs about 15 minutes and quits. I have cleaned out the carburetor and fuel tank. Changed the spark plug. Blown out the air filter. I have read that you can’t really get good readings on the coil with an ohmmeter, but for info purposes mine reads 9.70.
Thank you
Phillip
Thank you
Phillip
