This is one of these new types of engines that you don't change the oil,"just add if needed." And no primer bulb, or speed control. Northern Tool sells these for $189.00 with like $17 shipping. 7/8" wide X 3 and 5/32" length drive shaft. Key way is 3/16". Model # 104M02-0197-F1. 163cc
displacement. I am looking for a replacement engine for my 1998 walk behind FRP21600TV.
It originally had a Tecumseh 6hp engine on it; the owner gave the entire mower to me cause he ran it last year without checking the oil level and burned up the engine. He's known I've long been a Snapper fanatic since I've had a late 80's model. I put a new Briggs Intek 6hp engine on mine back in like 1996. That's the engine I swapped over to this '98 walk behind model just within the last two weeks. I replaced the drivebelt with brand new. Not an easy belt to find at your local hardware stores. The drive assembly is flawless and will run you around the block. The only reason I took this mower off my neighbor's hands was cause his father took meticulous care of it. It looked brand new to me. Too bad the son did something so stupid as to run it with hardly any oil it it. I also replaced the wobbly worn out front wheels with steel ones using an assortment of bushings, spacers and washers. What a difference. Not sure why Snapper used such plastic cheap stuff. Not only that, but they appear to be "Snapper" only, like just about everything else. The rear wheels are still ok.
So my Briggs 6hp Intek is showing signs of an oil leak on the left side of the engine in the muffler area. I can tolerate it but eventually want to replace it with a new one.
I question if this particular Briggs engine will fit on the deck or not. The muffler is on the right side of this model, unlike mine that is on the left. I got online with Snapper and did one of these "type and chat" deals. The bozo on the other end said I need to contact Briggs and Stratton. So I tried their 1-888# and that was like trying to get through Social Security. I hung up after 15 minutes.
Any feedback on how reliable this new 725 EXI engine would be welcomed as well as if it will fit my "new to me" 1998 model. If it won't fit, maybe something else will.
Thanks so much for any replies
PB
PB
