jakesmurray
- Jun 13, 2011
- 65
- 352
I've got a Murray rider with a Briggs 17 HP OHV engine. The problem is that when I go to start it, it fires up and runs way to high, and the throttle has no effect at all to the engine. It doesn't matter if it's in the run or idle position, it runs above WOT all the time. I inspected all the linkages, and they all appear fine. The throttle cable moves, and the choke works properly. I am thinking it is a governor issue, but I tried adjusting it, and it didn't change a thing. Any help would be appreciated...
