Briggs 17.5 turns 3/4 and stops????
unkwnmike
Took engine apart don't see anything broken. Turns fine but when i put sub back on it . Turn it it locks up. Turn it the other way locks up on the 3/4??? I believe its it the counter Weight any Idea.
Hydro-locked with fuel maybe?
Pull the plug. Crank over the engine. See if fuel dumps out the plug hole.
unkwnmike
this on a rebuild i believe it the oil slink.. with out it turns fine
So no fuel dumps out the plug hole?
If not valve adjustment time.
BEfore we go any further
What condition is the engine in right now
Together & in the mower or apart and on your bench ?
Did it rotate a full turn with the sump off ?
My bad. Reread original post. Engine was apart.
unkwnmike
engine on bench no internal parts broken. if i reassemble with out oil slinger turns fine.
Forest#2
Need engine info, model, type, code??????????
