lambostefan
- Jan 3, 2023
- 2
- 4
Hey there,
I got an old riding lawnmower (Intek 825, 122607, vertical) and just finished setting the valves and installed a new ignition coild. The carburetor needed service, so I took it apart and cleaned it. The good news is that the engine now is running again.
The bad news is, that the previous owner already tried to repair it and confused the linkage of the carburator and governor. I got everything right by bending the springs as seen in the parts diagram but i got a problem with the choke on the carb. Spring is installed and working, i can click the choke to open and close. Problem is now, that there is a hook on one side of the mechainsm and a little metalplate on the other side, which opens and closes the choke when getting the lever in position. I bend these things in the right position i think, but when choke is open now, the hook won't let it open 100% as it blocks the mechanism. I don't know if choke should be 100% (so that the plate is really 90°) open or only 1/4 like it is now in max position. Maybe you could answer me that question and if it should be 100% open in max position and if so where the problem could be.
Here a picture of the hook and the metalplate to move the choke (in disassembled situation):
Sorry for my not so good english and greetings from germany
