Maxrevs
- Feb 15, 2015
- 11
- 46
Briggs 10.5 fitted to a customer's 1998 CastelGarden F72 ride-on, motor was running fine but now runs rough and is near impossible to start with air filter fitted.
Model 28B707, Type 0146-01, Code 970318ZB
Carb is Walbro LMT 5-4993 (no fuel cut-off solenoid)
Mower came in for battery not charging and a service (tune-up). I'd removed fuel tank temporarily to get better access to wiring. I was testing alternator & regulator output (engine running normally with air filter), when after about half-a-minute the engine spluttered and died. Doh - I'd forgotten to reconnect the fuel hose.
After reconnecting the fuel hose the engine would not start. Then I started to smell petrol (gasoline) and noticed fuel running out of the carb. I assumed some debris in the float bowl had got sucked up and jammed the float needle open.
Stripped and cleaned carb, refitted to engine with air filter in position, turned fuel back on and no leaks. Problem solved, I thought. No. Engine would not start at all. Tested spark, put new plug in. Nothing doing apart from the occasional pfft.
Intending to re-check carb, I removed air filter and for some reason I just decided to try starting it - started first time and ran sweetly!!! Held air filter in position and engine dies, lift it up and engine runs.
Stripped and cleaned carb again, using new air filter, if I lower it into position slowly with engine running at max speed, I can just about keep it running but it's really struggling - not running evenly, occasional misfire - lift out air filter and it runs sweetly.
Is there an airflow restriction somewhere? If so, I can't find it.
Could there be something else going on that's not carb related?
My customer wants his mower back and I'm feeling guilty & stressed because the darn thing was running OK (apart from not charging) when he brought it in.
I would be SO GRATEFUL if any of you more experienced guys could offer some suggestions to help me out.
Thanks.
PS, I'll post some pics so you can see what I'm looking at.
Thanks.
