PTmowerMech
- Apr 16, 2018
- 396
- 3,017
This thing runs pretty good. Just not closed to the RPM's I think it should run. Adjusting the H out, really doesn't change anything, unless I'm closing it. Took the recoil off and found a pretty bad crank seal leak. Very wet around it.
Question: Would a crank seal have that same affect on the H adjustment?
