BR600 piston installation
kaliona
I am resealing the engine on this blower and want to be sure to install the piston correctly. How do I space the ring gaps relative to each other and relative to the crankshaft? Thanks for your help.
Only need to be 120 degrees between end gaps. Arrow on piston faces exhaust port. Snap ring end gap for wrist pin either face up or down.
jp1961
Hello,
I like to make sure the rings end gaps aren't in line with any machined ports (if possible), a mute point if the rings are pinned.
Regards
Jeff
Kinda a mute point since it is a 4 mix engine. A 4 cycle non ported cylinder and not a 2 cycle ported cylinder.
