Hi
My engine took a dump and needs to be replaced. The mower is in the middle of my driveway now. I know to disengage the transmission you need to move the lever in the back. It has been years since I last did this. I tried moving the lever towards the rear. But it is not moving. I just want to make sure towards the rear is the proper direction before I use more force on it.
Thank you
Thank you
