Bob Cat ZT 200 23hp Kaw
jfleming
Guys I have been on the hunt for this issue for quite some time and I am having no luck. What happens is the machine start just fine and runs just fine and sometime just out of no where it will act like the choke was pull, start running rough and smoking and then clears right up. It happens when just sitting at idle at time, it is purring like a kitten at low idle and then it goes into like a flood mode and acts up, smokes and recovers all on its own.
My money says it is time to remove, clean and rebuild the carb. Sounds like the float needle is not closing the float bowl properly, allowing too much fuel to enter the float bowl, which will result in a rich running condition. Might also be a bad float. Please do not double post, as it will be very confusing for everyone.
