Dixiemilker
- Aug 8, 2020
- 1
- 6
I am working on a kawasaki engine that is blowing the charge fuse. The stator is putting out 32 VAC at WOT. There is no resistance to either stator wire to ground. .02 ohms between the two white wires from the stator. 12.04 volts from switch wire to regulator. 15VDC from regulator going to switch when wire hooked up but -19.5 VDC when wire not connected. Red wire and charge wire gets very hot after mower runs for about 1 minute and blows charge fuse. What is my problem? Any help would be greatly appreciated. Steve
