I have a JD D130 22hp V tech. I have a hard time starting and saw a vid on internet about blowing air in gas tank. Tried and it worked. Prior to that I check for air in fuel line, Fuel Pump is spitting out gas, line from valve cover seems to be ok etc . I can start it but it takes a long time cranking BUT if i puff on the gas tank--it starts right up. After I stop and let it sit for an hour or so, it starts right up BUT if I let sit overnight --same problem- puff in gas tank and presto --starts right up? What am I missing?
