How do you change the blades on the 2018 Patriot 61" especially the center blade. Thanks
R Recon418 Forum Newbie Joined Sep 8, 2020 Threads 1 Messages 1 Sep 8, 2020 / Blades #1 How do you change the blades on the 2018 Patriot 61" especially the center blade. Thanks
Tinker Ty Member Joined Jul 15, 2020 Threads 0 Messages 30 Sep 8, 2020 / Blades #2 Lift the front of the mower, crawl under deck, loosen blade bolts... replace with new or sharpen old, and assemble in reverse order? I don't think those blades are timed. If your belt is cogged, they could be timed.
wrldtvlr Well-Known Member Joined Jul 18, 2020 Threads 11 Messages 127 Sep 8, 2020 / Blades #3 With a reasonable impact wrench, you probably won't have to brace the blade. Otherwise, a 2x4 or blade clamp.
