Teds
- Jan 14, 2017
- 2
- 82
I'd like to correct a bit of swirling that I attribute to blade track definitely out of spec on 7268, one side measures a bit high not front to rear. It's more noticeable at lower cutting heights.
But I'm a little unclear exactly where the shim is added. I'll figure it out but some advice wouldn't hurt.
Remove both halves of the muffler plate, correct? Then, place the shim between mower housing and top half of muffler? The original lawnboy instructions are a little cryptic. Thanks for any assistance.
