Blade bolt
Bobeaux
I need a blade bolt for a Craftsman T1200 riding mower. Any one have a part number for one? It's a 15/16th. It's fun when your mowing and the blade comes off?
The mower is a MTD and the nut needs the be tighten to 85-95 ft-lbs. The nut PN is 712-0417A Hex Flange Nut 5/8-18 (15/16 wrench or socket size). Complete spindle is PN 918-04822B or if just the shaft it is PN 738-1186A .
keakar
startech has you covered, but if you have ever changed the spindle and still have the old spindle somewhere, the top pulley nut is the same part number
