jekjr
- Jan 3, 2013
- 271
- 1,969
We change blades on two Tiger Cats daily. Some times more than once depending on the day and grass.........
We change them with a cordless impact and a floor Jack. On a few occasions we have had a blade that we can not remove. Impact won't break it loose. Cheater bar on a socket with a wrench fouled inside the deck on the bottom as a back up will some times get it to break. Yesterday we had to take a 1/8" blade on a 4" side grinder and cut the bolt off right at the bottom of the nut to get it out.
This was actually the second bolt we have had to do that to this year.
Have any of you had this problem? What did you do to rectify it.
