Black and Decker 24 volt rechargable lawn Mower
tonyp0626
Does anyone have any experience with the B & D 24 volt rechargable lawn mower. model # cmm1200? I have replaced the batteries and the mower woks fine, but the charger does not seem to charge the batteries. The indicator lights on the charger don't light up and I don't get any voltage when I test the connector end. I'm wondering if its the charger itself or the electronics in the connection on the mower handle.
sgmgarden
Welcome to the forum, I hope someone has an answer for you.
Briana
Welcome to LawnWorld!
I moved your thread to the Electric & Battery Operated forum. :smile:
MowerMike
From what you have described it is most likely the charger that is faulty. Did you connect the charger to another live outlet just to make sure ?
jpbarn45
The maintenance described in the service manual is battery replacement. (Possible two years). It charged up overnight. It had enough juice to mow 1/3rd acre lot with heavy spring weeds that were also a little wet without running out of battery juice.
There are no instructions for how to replace the battery - you are instructed to take it to a service dealer. Perhaps they will help you solve the problem.
