bevel gear oil not transmission
johnorlandi
Guys I guess I explained this wrong it is called in the parts manual "Bevel Gear & Side Plate group" it is for the POWER TAKE OFF not the transmission as I stated
And it says” fill with multi-purpose oil until oil touches the bottom”
What I posted
I have an Agco Allis 918 H and want to add a little oil to the transmission and it states that to use a multi-purpose oil
What is a multi-purpose oil, the internet says it is 3 in 1 oil but I think that is to light
What oil should I use in the transmission?
The multi-purpose oil Agco refers to is their PN 1685516 multi purpose hydraulic/transmission oil. Superseded to PN 1687064
The Simplicity Large Frame Garden Tractor Service & Repair Manual states in the Sundstrand Series 15 Hydrostatic Transmission specifications section, the hydraulic fluid to be Type A, F or Dextron automatic transmission fluid or Simplicity Multi Purpose Hydraulic Fluid.
Use only the same that is currently in the unit; unless, you are doing a complete oil change.
The only online source I found is below:
1687064
