GearHead36
- Apr 26, 2023
- 14
- 222
My search skills must be crap, because I can't believe this hasn't been asked before, but I can't find it.
Just watched a video that said that small engines should use high zinc oil. Is this true? That's the first time I've heard that. None of my engine manuals mention zinc. They all say use an oil with rating blah, blah, blah OR HIGHER. The "or higher" part includes modern oils that don't contain zinc.
So... Do I need high zinc oil? If so, what does the braintrust here recommend? I did a little searching, and didn't really find any good options. Most of the hits were racing oil or break-in oil, at $20+ per qt. I have to think that there's something cheaper out there that will work.
Some vintage motorcycles need high zinc oil, and some owners swear by Rotella. Would that be a good oil? 30W Rotella is under $20 a gallon at Wallyworld.
