Bent crankshaft Honda engine
taterpicker
Honda engine serial # GJAUK1027455MY03. Honda mower model # HRX217K6VYA, Serial # MAMA - 1019893. Is this engine worth repairing? Low hours, everything else is good.
Parts will run you over $200 and if you do the work yourself you need to make that call. For a shop to do the work NO.
