I have a 2010 LTX1046 I hit a small stump and bent a blade the one close to the discharge opening, I replaced both blades but the new blade on the side with the bent blade hits the deck slightly when I manually rotated it. I removed the spindle assembly and checked the bolt but it looks to be fine, now I am wondering if I tweaked the deck at the spindle mounting location. I put a level on the new blade that wasn't bent and slowly rotated it and it was level, I did the same to the other side and it seemed off level. Any advice as how to level the deck. It would seem to me that it should have not bent the deck.
