Belt & idler question
SHB
Have a 4 year old eXmark radius, 60” deck. First deck belt lasted about 400 hours. Got a replacement at Rural King (dealer wasn’t open), it ran about 8 hours then disintegrated. Got a replacement from the local dealer, have run it about 8 hours, just came loose. I checked the deck pulleys, they turn freely, however the spring loaded tensioner / idler pully is floppy, is that normal (Might be that way to compensate for differing deck heights). Anything else I should check? I mow a lot of fairly high grass, so things get a workout.
Tiger Small Engine
The tensioner pulley mounted on the arm should not be floppy. Chances are it has a worn bushing or bearing and needs to be tight and move freely.
Auto Doc's
Locate the product information tag on your machine and then go to this link and match up what you have for reference otherwise we are guessing:
