Bearing Ordering Help
bartles
Working on a Model HU700H, 961450024 01
I need to replace the rear wheel flange bearings as well as the drive pinion bearing in Part No. 585281901(adjuster). The bearings are not listed as an
available part in Husqvarna's website.
Thanks in advance,
bartles
Need ID and OD of the bearing. Probably will be 1-3/8 OD but can be 1/2, 5/8, or 3/4.
bartles
I'll take them out and let you know...thanks again!
The I.D., axle dia. is 1/2"
The bearing O.D. is 1 1/8", and the width of the bearing is 5/16"
The flange diameter is 1 1/4"
Thanks a bunch!
bartles
1madmouse
That bearing can be ordered from amazon and is part #587070202. you won't get the snap rings or circlip so make sure you keep the old ones.
