I have a B & S 19.5hp 31P677 on my John Deere lawn tractor. It wouldn't start because the compression release mechanism on the cam shaft had come apart. I have put a new cam shaft in along with tappets and adjusted the valves to factory specs. I had a bit of a problem getting the timing marks to line up, I couldn't get it in because of the push rod being in the way. I got it in and went to TDC and adjusted the valves. I am under the impression the I received the wrong cam shaft. It still is not starting and is difficult to turn over. Is there anything that can be done without tearing it back down and reordering another camshaft?
