csterl
- Oct 12, 2022
- 2
- 4
I am restoring a Tiger Cat with 52" velocity deck, and the welded in baffles on the deck are missing, with the exception of the center part. Can/should they be replaced and, if so, is a replacement part available? I am already having to patch holes on the deck, so a little more welding will not be an issue. I can get some 10 ga metal, but bending it will be a chore.
I will be using this at my house to cut an acre lawn only, no more commercial use for this guy!
