BadBoy ZT Electrical/starting issues...
MJO21
Looking for a head start on what could hopefully be the quick fix!!
Last week I was cutting grass with no problems at all. I got to a spot I wanted to cut lower so I lowered the deck. As soon as I hit the switch to lower the deck the mower died and would not restart. I ended up finding a burnt (fried hardcore) fuse, 25a inline fuse. I changed the fuse and cut the rest of the yard. As I was backing into the shed I got to my parking spot and pulled the emergency brake and the mower again died. I tried to start it again and got nothing. I replaced the same fuse again and all I got was a click from one of the (what I assume are) solenoid plugs (there are 4 in a row one the right side under the seat. It would not start or even crank, just click at the solenoid. I pulled the battery and it was reading 12.6v.
thoughts???
