Bad Luck
Jray1979
620 grasshopper. Last year it would run for 10 minutes or so and die. But would crank back up. Repair shop put a brand new kholer engine in. Mowed fine the rest of the 2 months. Started doing the same thing again last weekend so I replaced the battery think could be bad. But still no change. Any suggestions ?
First thing I would check is the gas cap. Run the unit with the cap loose and if the problem goes away the vent on the cap is plugged, replace the cap. If that doesn’t do it post back with all engine numbers and we’ll try again.
