Bad engines ? Three years ago I had a Cub Cadet rider with a Kohler engine that cracked right down the back and lost all of the oil.
jeepfxr
  • / Bad engines ? Three years ago I had a Cub Cadet rider with a Kohler engine that cracked right down the back and lost all of the oil.
Three years ago I bought a new Cub Cadet with the 22 HP Kohler engine. It was running fine until I went to start it and the engine cant make a complete revolution before coming to a dead stop and always in the same location radially. What is going on ?
If as the title says and the text does not mention the counter weight has come loose or apart.
So are we talking about two different engines, or something else. It makes it sound like the same engine was repaired or replaced and now that engine has failed. or are they two different engines with different issues.
MParr
??? So, you have two toasted engines in three years?
jeepfxr
two different engines and 2 different issues
jeepfxr
that's correct and it's not from lack of maintainance or failure to check/ change oil and filters
jeepfxr
where is the counterweight located ? big job ? thanks
So the only problem right now is the engine can not revolve 1 complete revolution
Can you turn it a full revolution by hand with the spark plugs removed ? ( two is even better )
If you turn it backwards does it stop at the same spot ?
Does it stop with click, klack , thud or just bind up ?
Is there any damage to the spark plugs ?
Had the gap closed up?
What sort of colours are the insulator noses ?
are they both the same ?
Do all 4 pushrods go in & out the same distance ?
If the engine is a single then the counter weight runs on the crank and goes back & forth between the crankshaft & the end of the crankcase
If it is a twin then there is no counterweight .
We can not see, hear smell nor feel your engine so you have to describe what is happen as if we were Tommy , the deaf dumb & blind pinball wizz .
Gregory5
Sounds to me like you are talking about Kohlers infamous "Courage" engine. They a known for this. Like the saying goes, "It takes a lot of Courage to own a Courage"
The thing is the title mentions one engine but the description talks about another. The engine in the title most likely is the Courage single which the block crack was possible. The engine in the description would be a twin cylinder either Courage or Command which would be another issue.
