Bad boy wants to stall out when in drive
Fleeman20
Hi my bad boy maverick was running fine now about a 1/2 hour into mowing it sties to stall as soon as I throw the arms into neutral its fine but as soon as I try to move weather the deck is on or not it wants to stall. Any suggestions?
SlopeMan2
The bi-pass connections on my control rods were shorting against the linkage when I would pull back on them. It took a long time to find this. The plastic cover, on the connector had finally worn through on the bottom, where you couldn't easily see it.
hlw49
Check the brake switch and or wiring at the brake switch
