BigBlueEdge
- May 27, 2015
- 6
- 69
I bought a Bad Boy Rogue this spring and have used it to mow my 7 acres multiple times now. I'm experiencing a persistent problem with it that is maddening and I cannot find a resolution to it. The front wheels knock the grass down and it doesn't spring back fast enough to get mowed so everywhere I go I have two 5" strips of grass sticking up. I've tried going slower and going faster and it doesn't seem to help. My dealer did some adjustments to the deck height & leveling and also made sure the belt tension was correct but that didn't change anything. I've been mowing at about 3.5 - 3.75" cut height, but I did try mowing lower and that didn't seem to help either... it just made scalping and 'cutouts' worse when the mower goes over bumps and ruts in the lawn. Also, this happens when the lawn is somewhat wet (mowing in the evening after a rain in the morning) and when it is dry.
As consistent as this is for me this must be a common problem for others who mow in the northern states and have similar grass types to mine. Would some type of high-lift blades help by pulling the grass up better?
Thanks,
Rob
Thanks,
Rob
