Bad Boy Maverick vs Spartan RZ-HD
BlakeC
I'm looking at a 54" in both the Bad Boy Maverick & Spartan RZ-HD.
I can get them both for basically the same price(Spartan is $250 more otd)
I'm trying to read and compare all of the specs and getting overwhelmed.
We have a VERY rough clay yard with THICK grass, so I have been looking at the Bad Boy because it has full front/rear suspension.
BUT, I started reading about the drives and that's where I got hung up.
Spartan has "Parker HTE Transaxles - 10cc Drive Motors"
Bad Boy has "3200 Hydro-Gear® 10cc Integrated Transaxle"
-Is one better than the other?
-Im not familiar with the drive types so I don't know what I don't know
Here are links:
Spartan - https://spartanmowers.com/rz-hd/
Bad Boy - https://badboymowers.com/zero-turn-mowers/residential/maverick-lawn-mower
Any advice is very appreciated!
MParr
I would go with the Bad Boy. The reason is because it has a keyed ignition switch.
BlakeC
Good point! I hadn't even thought of that. Not really a deciding factor for me tho lol
Spartan have not had any problems with the switch unlike Husqvarna but check the price of a replacement.
Just put a second one into a Husqvarna in less than 1 month
So that is over $ 1000 ( aus ) the customer has forked out on a mower with less than 200 hours on it .
No one in Oz can test the switch and from what I have been reading the same applies to the USA.
Similar problem with a Z-master, it's new module worked for 10 minutes then packed it in, so in this case it will stay bypassed
Same story , no one in OZ can test the Toro module either .
Have hear the same applies to Scags interlock module as well .
BlakeC
True, it's just something else that could go wrong, but I'm curious about the drives.
hlw49
We sell mowers with both hydros in them not having any problems with either one.
BlakeC
that's good to know!
is there a difference in either of them? is one heavier duty or higher end than the other?
MParr
Both are light duty commercial units. The Hydro-Gear has a tad more torque. The Hydro-Gear uses a readily available HG52114 transmission filter.
I would still pick the Bad Boy over the Spartan.
One of the original Bad Boy partners split from Bad Boy and started Spartan. Spartan was very recently acquired by Toro.
hlw49
The Parker HTE Transaxle uses their own HT1000 oil with change intervals of 1000 hours. It is around the $30.00 to $40.00 a quart range. It holds around 1.5 quarts per hydro. Where as the 3200 Hydro-Gear uses 20W-50 engine oil at around $10.00 a quart and change intervals at 75 hours on the first change and then 500 hours after that. It holds around 2.25 quarts per hydro. The parker has a cartridge filter and the hydro-gear has an external screw on filter.
MParr
There are other acceptable oils but, the change intervals vary.
From Parker Service Manual:
• To insure maximum HTE/HTJ Series transmission performance and life, use a Parker qualified oil. HTE/HTJ Series transmissions come factory filled with Parker HT-1000 transmission oil. Oil change intervals depend on the type of oil used. Always change the filter when changing the oil.
Qualified Oils Number of hours
Parker HT-1000TM (P/N 406030) 1U.S. Gal. (3.8L) 1000 Castrol Syntec 5W50 500 Amsoil AW ISO 68 500 Shell TTF-SB 500 Other* 250
*Must be premium grade synthetic based engine oil with a minimum viscosity grade of 15W40
Another reason to pick the Bad Boy.
