B6200 Tractor
b1mmuo27
I have the above tractor & I am looking for the lawn cutting manual for it. It has the centre 60 inch under belly pto driven triple blade grass cutter. I have the owners manual & service manual for the tractor but neither have the grass cutter in it. Thanks
You will need to get us the model number off the black and silver tag on the deck.
I’m not find a manual in pdf form to sent you. You can purchase them if you want to. If you do a search use this model number. RC60-72H for your deck. Sorry I couldn’t help more.
b1mmuo27
Couldn't find anything but I finally got it set up correctly. Blades are now level.:)
