B&S smoking on startup
jerrycmorrow
Got this 10+ year old self propelled mower with B&S engine. Starting this spring it smokes heavily upon starting. Smoke gradually disappears in about 5-10 minutes. Might still be a little smoke then but hard to say given the “grass” I cut; mostly dirt. I’m sure I’ve read about this before and suspect it might be valve seals but not sure. Little help would be very appreciated. TIA. Jerry
Scrubcadet10
Moderator
Staff member
Model and type numbers, please.
if it's a flathead engine, they will be stamped on the metal above the spark plug or on the flap above the muffler.
Scrubcadet10
Moderator
Staff member
It either going to be valve seals, or a blown head gasket.
Oil level is good as well?
Start the mower and let it warm up. shut it off, and remove the oil dipstick, look for whisps of smoke coming out of the dipstick tube, that is one tell tale sign of a blown headgasket.
jerrycmorrow
Oil level fairly good. Have to top it off every 3-4 uses of about 2 hours each
7394
My much older B&S flathead used to use oil too, when I service it, it takes 20 oz of oil (dry), I put in 18 oz of 30 wt, & add 1 oz of STP.
It seems much happier.
And STP is loaded with ZDDP.
Joed756
Is it the blue smoke of burning oil or is it white smoke indicating fuel? If it's white, install and use a fuel shut-off valve 1639240583793.png
