RichardHiggins
- May 18, 2012
- 1
- 6
Hello all,
New member here looking for some advice on my Craftsman mower. It recently started smoking real bad, and using up oil at an alarming rate. I know you're going to hate me for this, but I kept adding oil and kept mowing. Hey, the grass was REAL long! I knew I had a problem, but figured I'd address it once the forest was cleared. It took two refills to finish my 1 acre lot. After a while it sounded like it was running on one cylinder. I pulled the plugs and sure enough, the right side plug was gunked up real bad. I put in new plugs and some stop leak and kept going. This was meant as just a band aid until I could finish the lawn. Thing was, stop leak didn't help.
I purchased a B&S Repair Manual yesterday. The guy at the store said he suspected the Breather Tube. Once I figured out what a Breather Tube was, I found that it had come loose from the Air Horn! I cleaned everything up real good and reconnected that tube. Fresh oil, new filter, and gave it a whirl. No luck, still blue smoke real heavy.
So, given my limited knowledge here's my thoughts. I am suspecting either a blown head gasket or bad rings. My problem now is that the book calls for a Flywheel Holder at $65 and a Flywheel Puller at $15. I am afraid of investing in these tools only to find I can't fix it. Quite frankly, funds are limited.
So here are the main questions:
1 - Is there another way to get the flywheel off safely without those tools, or at least can I make my own Flywheel Holder?
2 - What are your thoughts as to what the problem could be?
Important Details
Mower:
Craftsman DYS4500
Briggs and Stratton Intek V-Twin 24HP OHV, Model 445677-0827-e1
Me:
Electronics Technician
Pretty handy with tools
Know little to nothing about motors. However, changed my own timing belt, drive belts, and alternator on my Honda Civic two weeks ago. (Love those Hanes manuals!)
Important Details
Mower:
Craftsman DYS4500
Me:
