B&S Flat Head Power Built 9.0 Info needed!
seagiant
Hi,
Was wondering if this engine has a Cast Iron Liner?
I was told it did?
Also looking for any opinions on it in general???
As usual we need all engine numbers before we can provide any help. Model, type and code.
seagiant
Hi,
Yea, I'll have that tomorrow, thank you!
seagiant
Hi,
Well this is what I could find on the Engine.
Ok, I see where there was a tag by the blower housing and it is gone?
FAMILY YB5X46252VB 274521
Hi,
that is the EPA number the numbers we seek are stamped into the blower housing usually above the spark plug but could be on a plate close to the rotating screen, or above the muffler.
seagiant
Hi,
Yes, as I said above that tag by the Blower housing is gone?
I can see where it was originally, but???
Thanks!
Remove the spark plug
rotate the engine so the piston is all the way down ( away from the head )
get a telescoping magnet and insert into the plug hole so it touches the sides of the cylinder
A cast iron liner will attract the magnet an alloy one will not
seagiant
Hi,
LOL! Now were talkin!
Never thought of that, but
Situation normal!
Thanks Bert!
So now when the kids complain about having to learn all this useless stuff at school you cal show them how it does fix every day problems .
