I have a B&S 15 hp Intek engine (model 31R777) in a Snapper riding mower. When cold, the engine starts, and runs well enough to mow the yard, although there are occasional misses. However, the engine will not idle. When the engine is running and I move the throttle from full speed to idle, the engine stops after a few seconds. Also, if the engine has been running and is stopped, the engine will not restart until it has cooled down. I checked the valve clearances. Exhaust was OK, but intake appeared to be essentially zero clearance, so I adjusted the clearances on both valves. That did not resolve the problem.
Any comments will be appreciated.
