My friend has a Bolens hand mower, that He said runs rough. I asked him to start it up, which started on the first pull. It was running rough. I pulled on the lever to increase the speed and then the engine stopped and won't restart. I blew out around the governor springs but still nothing. He said that it has previously started on the first pull. It acts just like it's not getting gas or else, maybe the governor spring got stretched out making it act like a shut off switch. I checked the primer to see if it was squirting gas and it is. Hopefully someone may have some ideas.
