hey guys. I have a situation going on with 2 B&S engines. both are 18hp. Engine number on one is (31H7770297E1), Can't read the other engine number because of rust on valve cover but engine cover says the same thing as the first engine. They look like the same series of engine. The problem is that when I start engine, right off it starts surging and then like backfire. does this no matter the throttle position. The second engine just surges no matter the throttle. ok, here is what I have done to remedy with no luck. 1. new spark plugs. 2. Cleaned carbs then replaced with new carbs. Cleaned coil contacts and Flywheel Contact. Replaced Flywheel key. Sprayed carb cleaner around head gasket area while running but no change in engine performance. No oil leaks around head gasket area. Any ideas why this is happening would be of great help.
