When I tried to use my Troybilt rider yesterday, it wouldn't start and I had to jump start it. It then ran very rough with a lot of white smoke for a few seconds and stopped. I can repeat it again and again with same behavior. Also, the oil dip stick smells gasoline.
The mower worked fine the last time I used it about 10 days ago. I do change oil and filter at end of every cutting season and check oil level regularly. My lawn is about 1/2 acres so I don't think I over taxed the mower. Is the engine blown, or is there a simple fix? Thanks for any tips.
