I am re-assembling this engine after a seize up and have lost the key-hole intake valve retainer 690656 which is no longer available. Are any other b&s retainers suitable or should I use the exhaust valve keeper and retainer?
The replacement inlet valve has a different fluted bottom section presumably suited to fit the key-hole. Does this require a different keeper?
There are a few available 690656 available on line in the US that cannot post to Australia.
Any suggestions would be appreciated
PaulD
PaulD
