knutrockney77
- Apr 15, 2015
- 1
- 4
So I have a TNT100-10041 4059A that is on a Toro Guardian 21711 mower from 1974. My grandfather had saved it for some reason(he was a toro dealer for 45 years) and I would love to get it running in his memory....but I can't for the life of me find the correct diagram for this carb. It has a primer bulb attached to the bowl nut, and I thought maybe he added it himself but on the top shroud of the mower a sticker says that the mower is primer equipped so it had to have came stock like that. The primer has a tear in it so I either need some help tracking one down, or if its okay to just use a different bowl nut that isn't set up for priming. Automagic is stamped into the side of the carb if that helps shed any light.
Thanks
Thanks
